I'm a beginner trying to learn to use AnyBody.
My question is:
How can I use the events (heel strike /foot off, generated in Vicon) in Anybody, so that my Trial length is only from one heel strike to another (and not the whole C3d. Data length)?
I've found the Events, but don't know how to use them in the code the right way on the right place.
It is not something i have tried, but in the TrialSpecific.any file you can set the FirstFrame and LastFrame, so if your event data contains the frame numbers it should be a matter of pointing to these data in the C3DFileData folder directly instead of writing the numbers in the TrialSpecific file.
