If I want to generate data and import them to any bode model (gait
model),what kind of data is required and how many sensors are needed?
In fact,for constructing my model,what should I do?(exception physical
properties of model such as:weight,lenght,…)
To build a gait model you basically need the following things:
Mocap data (an example of a useful marker configuration can be found
in the Gait3D model)
Force plate data synchronized with the mocap data
Anthropometrical data, including weight
The Gait3D model is a good example of a model using the items above.
It is difficult to say how many markers you will need it depend on their
location; again the Gait3D is an example of a suitable marker set. Basically
you need to have enough markers for driving each of the dof in the model in
a good way.
Gait models are not the simplest models to start with; i would recommend
doing the tutorials first, please see
best regards,
Jalal.Arabneydi
