Hi Yuening
So you wanna constrain the pelvis in all DOF exept from moving in the
x-axis?
And then the rest of the leg should be driven with the kinematic markers?
Christian, AnyBody Support
— In anyscript@yahoogroups.com, yuening ma <yueningma@…> wrote:
> Hi Christian!
> what I want to do is just to find changing of musles forces of the
leg during certain displacement input from the foot.
> The pelivs main motion is along human’s axes.,that is the x coord.
> best regards
> yuening
> ----- ÔÂʼ�ʼ� ----
> �ˣ� AnyBody Support <support@…>
> �ռ��ˣ� anyscript@yahoogroups.com
> 2008/1/24(), 5:11:04
> [AnyScript] Re: Help: tolerance about the constraint
> Hi Yuening
> The error you get is because your model cannot satisfy the kinematics,
> you try to drive the model to something that it can’t.
> You should maybe think of how you wanna drive the pelvis of your
> model? Maybe you could explain in a bit more detail what exactly your
> model should do?
> Best regards
> — In anyscript@yahoogrou ps.com, “yueningma” <yueningma@ …> wrote:
> > Hi!
> > wwhen running the model,The modelinformation of the study showded
that
> > the DOF of the model is correct. But when running the knematic
> > analysis ,the system said fail to resolve knematic constraints. More
> > description as the following
> > " constraints No39 above error tolerance 0.000001, error-0.544"
> > About 13 errors like it.
> > what should I do?
> > thanks for your time
> > Yuening
> ___________________________________________________________
�Ż䴫��ף���Ժؿ�
http://cn.mail.yahoo.com/gc/index.html?entry=5&souce=mail_mailletter_tagline
