»Ø¸´£º [AnyScript] About Muscle
Leng-Feng
I have uploaded it.
I used the standingModel and just modified Driverpos’s value of
“Lheel(AnyKinEqSimleDiver)” in " Jointsanddrivers.any".
what I want to do in this model is to take up the heel for 5CM in y coordinate
.According to it, the muscle forces changing of the thigh is being insterested.
Yuening
----- ԭʼÓʼþ ----
·¢¼þÈË£º Leng-Feng Lee <lengfenglee@yahoo.com>
anyscript@yahoogroups.com
2008/1/15, 4:13:43
Re: [AnyScript] About Muscle
Hi yueningma,
To better understanding your questions, can you
please upload your model to the File Section on
Yahoo Group? You can create a folder call
“yueningma” and upload your files to this folder.
We can then see what you are trying to do and
will try to answer your questions.
Leng-feng Lee
— yueningma <yueningma@yahoo. com.cn> wrote:
> Hai my friends. Some questions want to ask.
> I use the standingModel to learn the muscle on
> muscle forces of the
> spine when standingModel posture changing.
> Now I did a simple one. That is to taking up
> the heel by using the
> standingModel. I did it by changing the
> elbowpronation parameter’s
> value. After run it, now forces finally. what
> should I do?
> waiting for every reply.
Never miss a thing. Make Yahoo your home page.
http://www.yahoo. com/r/hs
   ___________________________________________________________
http://cn.mail.yahoo.com/gc/index.html?entry=5&souce=mail_mailletter_tagline
Hi Yuening,
From the model you upload it doesn’t seem to have
any problem. The reason that you didn’t see the
force in the muscle is because the resulting
muscle forces is single valued.
The single value muscle forces is the result of
only one time step used in this standing model
study. If you plot this single value using
AnyChart2D3D, it will not show anything, giving
an impression that there is no muscle forces.
A better way would be to use the “Bar” plot
setting on the AnyChart2D3D.
As an example, after you performed the
InverseDynamicAnalysis, open a AnyChart2D3D, and
you can plot all the muscle forces Fm in the
Right Leg by output the following in the “Y:”
input field on the AnyChart2D3D:
Main.Study.Output.Model.HumanModel.Right.Leg.Mus.*.Fm
You will then able to see all the single valued
muscle forces (Fm) for all the muscle in the
Right leg in the chart. I have attached a figure
to illustrate this process. You can download this
picture (Filename: “StandingModel.jpg”) in the
File section, inside folder “Yueningma”.
Hope this helps.
Leng-Feng
— yuening ma <yueningma@yahoo.com.cn> wrote:
> Leng-Feng
> I have uploaded it.
> the heel for 5CM in y coordinate .According to
> being insterested.
> Yuening
> ----- ԭʼÓʼþ ----
> 2008/1/15, 4:13:43
> Hi yueningma,
> folder.
> Thanks,
> Leng-feng Lee
> on
> > should I do?
> ____________ _________ _________ _________
> removed]
________________________________________________________________________________\
http://www.yahoo.com/r/hs
