I use my own BVH file collected from XSens MVN and had no GRF data. When running for inverse dynamics, I get the following errors.
Muscle recruitment solver : solver aborted after maximum number of iterations
I have searched the forum and try to adjust LimitDistHigh and friction coef, however, I am not sure to adjust the value higher or lower.
Besides, I could not to adjust the Main.Studies.InverseDynamicStudy.InverseDynamics.Criterion.Power = 2", because the "set value" is grey.
Can you help to check it?
Thanks!
Best,
Shitan
