Hello, I want to change the muscle type and muscle strength index, how to display "Active Tools" in AnyBody software? The AnyBody in our lab does not have this configuration window. Thank you very much!
Hi @Anybody998
To use the BM configurator tool you will need a version 7.2 or above of the AnyBody Modeling System and a version 2.2 or above of the AMMR.
Can you verify that you have the needed verisons ?
Bjørn
Hello! @Bjorn
Thank you very much for your reply! I can only use version 7.1 for the time being. How to change muscle strength in version 7.1? How to change Hill muscle and normal muscle?
best regards
yuyue
Hi @Anybody998
You can find the body model statements for switching between the Hill type muscles and simple muscles here:
To change the muscle strength you can use the overall strength factors that work per body region - those you can find in the Main.HumanModel.StrengthParameters folder.
There are also per segment factors such as: Main.HumanModel.Scaling.StrengthScaling.Right.Humerus.StrengthScale
and lastly you can open up to each individual muscle and set the strength directly if needed.
Bjørn
