I am using the Plug-in-gait_simple FullBody_GRFPrediction model.
I want to save some variables using AnyOutputFile class. I can use this class and added it inside the inverse dynamics study. The problem is that the text file is saved in the Setup folder, but I want to save it in another arbitrary folder. How can I customize the save path of this class?
Thanks for your response.
Actually, I tried a lot, but I couldn't do so.
Right now, the file is saved in Setup folder, but I want to save it in another folder in the same directory as Setup folder. Let's assume its name is X. So, I have to go back one folder and then go to X folder.
Can you please help me with this?
That would also be great if you could tell me how can I get the directory of my main file.
