Data for FEA
Dear Sir
How constraints for a FEA model can export from Anybody model without using Any2Abaqus converter?
The obejct AnyMechOutputFileForceExport can be used to export all the forces acting on a segment into an output file.
If you are not using either Abaqus or ANSYS for which we have converters you have to setup a conversion of this file into the format you need.
Which FE package are you using?
Sir we have Abaqus software.But our any2abaqus licencse is expired.So we are enable to export loads and boundary conditions now.Now we are doing it manually.Can we export boundary condition manually?
The export option AnyMechOutputFileForceExport i mentioned in previous post is unaffected of the any2abaqus being availble or not, but you will manually have to alter the file format to become an abaqus load file.
