What directions are indicated by the +/- sign for the following joint moment outputs. For instance, what does positive hip torque corresponds to : hip flexion or extension?
Main.HumanModel.BodyModel.SelectedOutput.Right.Leg.JointMomentMeasure.AnklePlantarFlexion
Main.HumanModel.BodyModel.SelectedOutput.Right.Leg.JointMomentMeasure.KneeFlexion
Main.HumanModel.BodyModel.SelectedOutput.Right.Leg.JointMomentMeasure.HipFlexion
Main.HumanModel.BodyModel.SelectedOutput.Right.ShoulderArm.JointMomentMeasure.GlenoHumeralFlexion
Main.HumanModel.BodyModel.SelectedOutput.Right.ShoulderArm.JointMomentMeasure.ElbowFlexion
Since each of these output are defined as flexions for each joint, does + sign always indicate flexion direction of a given joint and vise versa?
Jeevan
