I just follow the webcast “AnyGait: Getting quickly from mocap to individualized musculoskeletal analysis (John Rasmussen, 15. December, 2009)” and want to test it by myself. But without modify something, the main.any can`t be loaded in. There comes the following error:
I use AnyBody V 4.0.2 and haven`t done some kind of modification on the example, instead of copying the folder into a new directory like it is shown in the webcast.
Unfortunately, AnyBody version 4.0.2 does not support the GaitLowerExtremity example in the AMMRV1.2 repository.
The GaitLowerExtremity example needs the kinematic solver for over-determinate systems. But this new solver can be supported at the AnyBody version 4.1 or later versions.
So I’m sorry but I’d like to recommend you to upgrade your AnyBody version.
you can only change the Gait Velocity/ speed of walking by telling the patient in the Gait Lab to walk faster!
These kind of variables cannot be changed in AnyBody. So you have to find C3D files of subjects walking at different speeds.
thanks for your answer. So I`m glad to make some Vicon-MoCap gait analysis next week. With this it should work, I hope.
In this moment I try to import test-c3d-files into AMS. That seems to be a little bit circuitous in V 4.0 - Is there something in addition to the AnyBody tutorial or the description in the Repisotory, which could help me. For example one problem is now: The Rep-model got 4 force plates and with that a lot of Forces defined for that. And my MoCap-data got only 2 plates. Is it easy to change this in the (I think) enviroment.any ?
But after the AnyBody version 4.1, this gait application is not supported officially.
Because after the AnyBody version 4.1, we have much more advanced solution for gait analysis using our over-determinate kinematics solver.
So, I’m sorry but I can’t answer about using this GaitApplication2 from now.
Now I have temporary the possibility to use the AMS V 5.1 and have another problem.
In GaitLowerExtremity and GaitFullBody the tutorial says (as described on top)
how to integrate an own c3d-file. That doesn`t work.
It says something like that:
ERROR(OBJ.FILE1) : C:/xyz/ModelSetup.any : ModelSetup.C3DFileData.FileName : Problem with file : C:/xyz/abc.c3d : The parameter names in the c3d file are not unique. Renaming adding _DUPLICATE_ERR# to second instance of a parameter name is done.
And if I compare my c3d file with the example file, I see that I have a lot of more Markers and analog data in my file. Could this be the problem?
In the last 2 weeks, we`ve made some own MoCap gait-analysis c3d-files. Now I try to use the data with the GaitFullBody model.
After modifying the "TrialSpecificData.any" and the "ModelSetup.any" files, I got some more errors. Some I could correct, some not.
It says:
"ERROR(SCR.EXP1) : C:/D..n/a..n/A..n/A..y/A..x/A..2/A..n/M..s/M..y/EnvironmentAutoDetection.any : Defined At : C:/D..n/a..n/A..n/A..y/A..x/A..2/Body/A..n/T..x/M..p/ForcePlateType4AutoDetection.any : '' : Illegal operation for given argument types : 'AnyFloat[6][1]' '' 'AnyFloat[6][7980]'"
Obviously it have problems with my analog data. Is it a possibility to upload my c3d-file and start a open discussion about the needs of changing in it? I have the misgiving that after correct an error, the next is still waiting ;).
