I want to use AnyShortestPathMuscle for wrapping
I added 3 refnode and 1 segment ( origin, Ins1, Via point, and segment).
and I added InitWrapPosVecArr for initial condition, but i got this message.
WARNING(OBJ1) : E:/1…s/A…y/A…s/A…e/C…s/AnyShortestPathMuscle.any(134) : Muscle1.SPLine.InitWrapPosVecArr : One array of 3D vector is expected for each segment of the string in AnyKinSPLine.
and start operation doesn’t work.
ERROR(SYS1) : Operation : Unknown error : ‘No Class Information’
how can I solve this problem? thank you
below is total example code
#define MUSCLE1_VIA_POINT // Extends the example with a via-point for the muscle
Main = {
// The actual body model goes in this folder
AnyFolder MyModel = {
// Global Reference Frame
// AnyDrawRefFrame drw={ RGB = {0,0,1}; };
AnyRefNode CylNode ={
sRel={0,0,-0.05};
AnySurfCylinder Cyl={
Length=0.30;
//Try to play around with the radius of the cylinder
//Look at the variable Main.Model.Muscle.LmtDot in the chart window
//When the muscle is wrapped around the cylinder LmtDot will have the
//size of the cylinder
Radius=0.05;//Radius of the cylinder
AnyDrawParamSurf drw={};
AnyDrawRefFrame drw1 = {};
AnyRefNode SurfaceNode ={
sRel={.Cyl.Radius+0.0001,0,0.1};
// AnyDrawRefFrame drw={ ScaleXYZ={1,1,1}*0.2; };
//Mucle node
AnyRefNode MuscleNode ={
sRel={0.3,-0.03,0};
//Make a blue coordinate system at the node
AnyDrawNode Drw={RGB={0,0,1}; ScaleXYZ={0.01,0.01,0.01};};
AnyRefNode MuscleNod ={
sRel={-0.2,0.2,0};
AnyDrawRefFrame Drw={RGB={0,0,1}; ScaleXYZ={0.1,0.1,0.1};};
}; // Global reference frame
//make a segment
AnySeg Segment ={
r0={0.25,0,0};
Mass=1000;
Jii={0.1,0.1,0.1};
AnyDrawSeg drw={RGB={0,0,1};};
AnyRefNode node1 = {sRel={-0.5,0,0};};
AnyRefNode node2 = {sRel={0.0,0,0};};
//make a revolute joint
AnyRevoluteJoint Joint ={
AnyRefNode &ref1=.Segment.node1;
AnyFixedRefFrame &ref2=.GlobalRef;
Axis=z;
//make a driver
AnyKinEqSimpleDriver Driver ={
AnyRevoluteJoint &ref1= .Joint;
DriverPos={pi};
//Set the velocity to 1 in oder to be able to measure
DriverVel={1.0};
Reaction.Type={Off};
//Muscle strenght model
AnyMuscleModel MuscleMdl={
F0=3000;
AnyShortestPathMuscle Muscle1 = {
AnyMuscleModel &MusMdl = .MuscleMdl;
AnyRefNode &Org = .GlobalRef.MuscleNode;
AnyRefNode &Via1 = .GlobalRef.MuscleNod;
// AnyRefNode &Via2 = Main.MyModel.GlobalRef.CylNode.SurfaceNode;
AnyRefNode &Ins = Main.MyModel.Segment.node2;
AnyDrawMuscle DrwMus = {Bulging = 1;};
AnySurfCylinder &Surf1 = .GlobalRef.CylNode.Cyl;//reference to the cylinder
SPLine = {
StringMesh = 25;
AnyMatrix InitWrapPos = {
transf3D({ 0.05, 0, 0}, &.Surf1 ),
transf3D({ 0, 0.05, 0}, &.Surf1 ),
transf3D({ -0.5, 0, 0}, &.Surf1 )
InitWrapPosVecArr = {&InitWrapPos };
};//SPLine
};//Muscle1
}; // MyModel
// The study: Operations to be performed on the model
AnyKinStudy MyStudy = {
AnyFolder &Model = .MyModel;
//RecruitmentSolver = MinMaxSimplex;
Gravity = {0.0, -9.81, 0.0};
tEnd=2*pi;
Kinematics.SmallStepAssumptionOnOff = Off;
}; // Main
