I am trying the BVH mocap example with my own bvh file and full body model, and I get:
0.1.0) Kinematic analysis...
Progressing to solve kinematic optimality conditions and hard constraints.
Failed to solve kinematic optimality conditions and hard constraints after 5 fallback attemps.
Constraint violations for study 'Main.Studies.MarkerTracking' :
Constraint #96 is above tolerance 1e-06, error = 0.000002, constr. #3 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.HumeroUlnarJoint.Constraints'.
Constraint #394 is above tolerance 1e-06, error = 0.000001, segment constr. 'Main.HumanModel.BodyModel.Trunk.SegmentsThorax.ThoraxSeg'.
Constraint #402 is above tolerance 1e-06, error = 0.000001, segment constr. 'Main.HumanModel.BodyModel.Trunk.SegmentsCervicalSpine.C7Seg'.
Constraint #403 is above tolerance 1e-06, error = 0.000002, segment constr. 'Main.HumanModel.BodyModel.Right.ShoulderArm.Seg.Clavicula'.
Constraint #404 is above tolerance 1e-06, error = 0.000002, segment constr. 'Main.HumanModel.BodyModel.Right.ShoulderArm.Seg.Scapula'.
Constraint #405 is above tolerance 1e-06, error = 0.000004, segment constr. 'Main.HumanModel.BodyModel.Right.ShoulderArm.Seg.Humerus'.
Constraint #406 is above tolerance 1e-06, error = 0.000004, segment constr. 'Main.HumanModel.BodyModel.Right.ShoulderArm.Seg.Ulna'.
Constraint #407 is above tolerance 1e-06, error = 0.000001, segment constr. 'Main.HumanModel.BodyModel.Right.ShoulderArm.Seg.Radius'.
ERROR(OBJ.MCH.KIN3) : AnyMocapModel.any(41) : MarkerTracking.Kinematics : Kinematic analysis failed in time step 23 : Position analysis is not completed
Since it can go through first 22 steps, may be the joints has some limit to perform this movement?
I have searched the forum and didn't find a valid solution.
1. changing the tolerance: already 1e-5,
\AnyBody.7.4.x\AMMR.v2.4.1-Demo\Tools\AnyMoCap\InverseDynamicSettings.any(4) : Kinematics.KinematicTol=1e-5;
and I tried to change the 1e-6 config found in "all loaded model files", not working either.
\AnyBody.7.4.x\AMMR.v2.4.1-Demo\Body\AAUHuman\Arm\Muscle.any(55) : RelTol = 1e-6;
\AnyBody.7.4.x\AMMR.v2.4.1-Demo\Body\AAUHuman\Arm\Muscle.any(1965) : SPLine.AbsTol=1e-6;
...files does not seem like a config
2. check the movement itself:
How does the 'Constraint' work? I assume they are joint rotation degrees, is there a way to see these limit values and joint real time value (like output pathes)?
Thanks!
/querye
