Hello altogether,
attached code (from the AnyBody Tutorials Lesson 3: Abaqus Interface — AnyBody Tutorials v7.3.4)
AnyBodyStudy Study =
// Include the Model within the Study
AnyFolder &Model = .Model;
tEnd = 10.0;
Gravity={0.0, -9.81, 0.0};
nStep = 5;
// Overdeterminate solver is needed while using the
// soft default mannequin drivers.
Kinematics.SolverType = KinSolOverDeterminate;
InitialConditions.SolverType = Kinematics.SolverType;
//=========== AnyFE OutputFile in *.xml format =====================
FileName = "files_in/clavload.xml";
/*NumberFormat =
Digits = 15;
Width = 23;
Style = ScientificNumber;
FormatStr = "";
UseRefFrameOnOff = On;
RefFrame = &.Main.HumanModel.BodyModel.Right.ShoulderArm.Seg.Clavicula.localrefframe;
XMLformatOnOff = On;
Segments = {&.Main.HumanModel.BodyModel.Right.ShoulderArm.Seg.Clavicula};
gives me the error
ERROR(OBJ.FILE1) : ClavFE.main.any(71) : FE_out.FileName : Problem with file : clavload.xml : The output data file does not exist and cannot be created.
Do you have any idea why?
OS: Win10
Best Regards,
Max
