I’m having some trouble with the StandingLift Model. I’m trying to get the model to put down the aquarium to the ground or just as close as it can get. Right now the model stands with a straight back instead of the bend back it normaly has.
I know that the aquarium contains a driver funktion and I have already tried to change the coordinates but everytime i run the model, only the arms start moving.
I would like the model to just bend over and not bow its knees.
My question therefore:
Is there a driver in the lower back or hip which only makes the upper body move?
This model has not been designed to put the box down originaly, so a few changes are needed. In the JointsAndDrivers file there is a driver for the trunk flexion/extension, it is fixed now but you can make it bend by giving it a velocity in the Mannequin file. I guess you also need some motion in the hips and knees. They are also fixed, so you can add the velocity in the Mannequin file again.
With that and giving the right trajectory to the box it should be ok.
Thanks for your reply. It helped me a bit
After several tries, I’m unfortunately still having some troubles making the model bend over perfectly. I was wondering if I could call one of you guys and get some further instructions?
Ok, I will try to describe the problem as best as I can.
I want the model to bend over (only in the back) while it is holding the aquarium.
Everytime I run the model I get this error and it looks like the joints in the right arm is dislocated (look beneath the message).
Hope you can help me
Joakim
Kinematics (Operation: Main.Study.Kinematics):
0.0) PreOperation (Operation: Main.Study.Kinematics.PreOperation):
0.0) InitialConditions (Operation: Main.Study.InitialConditions):
0.0) …Design variables have been updated.
0.1) …Load time positions have been re-established.
0.2) …Kinematic analysis completed. The kinematic constraints have been resolved.
0.3) …Initial conditions are fully updated.
