How can the SitToStand_Exo-main model be correctly run?
Hello, I am a beginner in AnyBody, mainly aiming to learn human-machine coupling of exoskeletons. I downloaded the source code of SitToStand_Exo-main from GitHub. How should I operate, in which folder should I place it, and how can I run the model? My version is AnyBody 7.1
Hi Ronin,
You can download the model and locate it in any folder that you normally use for keeping your data.
Before you load the file in AnyBody, you must install the AMMR files from AnyBody. Please see herehttps://anyscript.org/ammr/ammr_installation.html on how to get the AMMR files.
Then, you should open the StandingExo.Main.any file from the Sit to Stand Exo model in AnyBody. In there you must change the line that includes the libdef file to include the libdef file from your demo AMMR. Please see this link for more info.
Then you should be good to load the model. I am not sure, but there may be some issues since you are working with an older version of AnyBody
