However, it always failed at step -Kinematic analysis failed in time step 0 : Position analysis is not completed. Here is the model BenchPressTest (1).zip (505.5 KB)
Could you please give me some hints? Thank you!
Before I look into your model, have you had a look at our wiki page concerning connecting an exoskeleton to the human model? It could be a good idea to follow the approach listed over there and build the model in incremental steps. Could you please have a look and let me know at what step are you on right now?
Could you also briefly summarize the changes that you have done in the model, specifically the drivers that you have added? I can see about the exoskeleton joints and the connection to human from your previous post, but how about the joints and drivers between between the weight and the human? Are you able to run the bench press motion without the exoskeleton?
What you have made in the image are kinematic measures - but no connections.
You need to add constraints (AnyKinEq or derived classes) that utilize these measures.
Try to complete our getting started tutorials - that will take you through the different objects and how to construct what you need. Lesson 3: Connecting Segments by Joints — AnyBody Tutorials v7.4.0
