How to include human measurement in the maniquen
hello, morning just asking how can we adjust the scaling of human body on the example that was given. i keep doing it but there in no change on the model itself and it keep denied or rejecting
Hi Rizal,
Welcome to the forum, which model are you trying to modify?
If you get warnings which says the model can not be saved, it might be because you are trying to modify the default installed model, this version is write protected.
You should use the demo tab to install a new AMMR on your hard drive, please see https://github.com/AnyBody/support/wiki/AnyBody---How-to-get-the-AMMR
Thank you for the info. The software is an university license. Now im having a problem how to include the human measure such as weight, height and others. i have a sitting model. how can i include the coding in the model. i try to add in the #path BM_Scaling_Anthro_File but could't manage to run the simulation.
Hi rizal
Please have a look at e.g. the model StandingModelScalingDisplay in AMMR it displays how this is done.
