DWAN
(LEE DONGHWAN)
1
Hi there,
I want to lock SubTalar joints(Left, Right) in my model.
The problem is even i inserted the range of left and right SubTalar joints to [0,0]. Furthermore, i set SubTalar eversion off both legs.
But the values are measured and it is not what i expected.
Did i miss something?
Thank you,
Best regards.
toerholm
(Søren Tørholm)
2
Please ensure that the switches you have around the limits are nor preventing this code to be active.
Please also check that the code is include or referred to from the study you are running.
Both these things would could explain this .
Lewis-H
(Lewis Hamilton)
4
Thanks! this information helped!
Lewis
system
(system)
Closed
5
