I am trying to modify the human template like adding nodes to an already created Segment and removing the ligaments for example. however, whenever I try to modify the files an error occurs where access to the AMMR files is denied.
can I do this modification with a different method? or should I do something first to allow access to the files?
This is because you might be trying to modify the AMMR which is part of the installation.
Please install your own version which you can modify as you like, to do that click the assist icon and then the demo tab, which gives you a possibility to install your own AMMR version. Please choose a location on your disc with write access so not in programs folder but in your normal working directory.
