I want to import joint angles as text file. I used the AnyFunInterpol and AnyKinEqInterPolDriver Functions. When I want to run the model, it always stuck at “evaluating constants…”
Can someone tell me what I’m doing wrong?
I started working with AnyBody recently, so a step by step introduction would be fine…
It is a bit difficult for me to help with these old versions. If you look at the reference manual for your two proposed classes, you will get a lot of information on how to implement them. If you look at the bottom page for AnyFunInterPol, you will find a demo. The example from here looks like this:
/// Example 2: Simple interpolation function importing data from a csv file
AnyFolder Ex2_simple_data_import = {
/// Definition of an interpol function
/// that retieves the data from an external file
AnyFunInterpol TestFfile = {
Type = Bspline;
FileName = "AnyFunInterpol.dat";
AnyVector vfile = 0.025*TestFfile(1.5);
I will, of course, recommend a newer version of AnyBody.
But I have to other questions.
When I run the Kinematics I get the message:
3 unsolvable constraint(s) found
264 independent constraints and 273 unknowns
How can I change that?
and another question…
how can I check if the joint angles of the model match with the joint angles of my measurement System?
[SIZE=2]For example for the hip angles means an angle >=0° Extension and <0° Flexion (See Picture in the attachement)[/SIZE]
[SIZE=2]Where can I see if the model of AnyBody has the same settings?[/SIZE]
