Hi there,
Using the FreePosture model with joint angles for the knee and hip flexion of both legs driving the kinematics with all other segments being constrained to zero, I've run the Inverse Dynamics tool with muscles set to ON:
#define BM_LEG_MUSCLES_BOTH ON
#define BM_ARM_MUSCLES_BOTH ON
#define BM_TRUNK_MUSCLES ON
I'm getting 'Overloaded muscle configuration' errors and in Model View the model is looking pretty strange...attached is a screenshot from some time in the Inverse Dynamics analysis.
Here is the output from AnyBody when ID is run: ******************************************************************************** - Pastebin.com
At the end I get this error:
ERROR(OBJ.MCH.MUS4) : C:/U..s/j..1/A..a/R..g/A..y/D..s/A..o/A..n/M..s/M..e/FreePostureFullBodyStatic.Main.any(107) : Study.InverseDynamics : Muscle recruitment solver : solver aborted after maximum number of iterations
I have the same problem when I run ID with the muscles turned off. Please note that I have not set any ground reaction force prediction or grounded any parts of the body (as I still don't know how).
Jared
