Please check that the drivers you have added to the model do not have the reactions switched on by mistake, the default is on.
This means that if you are driving e.g. a knee flexion with a driver on a kneeflexion dof it will add a torque reaction by default and the muscles will not need to carry this dof.
Please in the driver write e.g. (for a driver with one dof)
This error means that one or more DOF in the model can not be balanced by either muscles, ligaments or reactions forces.
Please try to add back again the reactions you removed one by one to reveal which DOF is causing the problem. Once you know which DOF it is you will need to evaluate the cause for it, e.g. lack of muscle being able to balance the DOF.
