What is the role of the leg trunk interface? What is the difference between leg to trunk and trunk to leg in configuration.
How to get the leg's strength index? Is there any relevant literature recommendation or how this value appears? If I want to analyze running, how much should I take the leg's strength index?
The interface scaling allows body parts originating from different sources to be paired. Both trunk and leg comes with a pelvis and the interface scaling ensure that they match up. With the intrface scaling done additional subject scaling can be done afterwards.
The strength index is a quick way to increase or decrease the strength of a limb, it will impact all muscles in the body part, it acts as strength scaling factor.
