I have a few questions and I have encountered some problems with driving the MoCap full body model for a simulated lifting and lowering task.
Questions:
- For this specific analysis there were no force plates used. Can I run the model without this data? If so, what commands do I insert into the ForcePlate input file. I have inserted:
AnyFixedRefFrame GlobalRef ={
Origin={0,0,0};
AnyDrawRefFrame drw={ScaleXYZ=0.4*{1,1,1};};
However this does not appear to be correct.
- The motion capture data was captured using Xsens motion capture system. Do I have to create new markers or can I use the markers already established in the Marker file?
Problems:
I have encountered a problem with the TrialSpecific file in the input folder. It seems to come up with an error after I have added the C3D file and anthropometric data. I only changed the file name, stature and mass. I do not have the other segment lengths or stating angles. Is this an issue?
The error message in the Trial Specific file consists of:
ERROR(SCR.SCN6) : C:/U…s/k…n/D…s/A…y/F…1/M…l/I…t/TrialSpecificData.any(49) : ‘UseUpperExtremities’ : Unexpected character.
The error message in the main model consists of:
ERROR(SCR.SCN1) : C:/U…s/k…n/D…s/A…y/F…1/M…l/MoCap_FullBody.main.any(1) : Cannot open file : C:\Users\kirsten.huysamen\Documents\Anybody technology\Frank 011\libdef.any
Could you please help me. I have loaded the file as an attachment.
Kirsten
