Muscle recruitment solver
ERROR(OBJ.MCH.MUS4) : C:/U…s/t…k/D…p/A…3/AMMR/A…n/E…s/S…l/SitUpModel.Main.any(70) : Study.InverseDynamics : Muscle recruitment solver : solver aborted due to singular KKT matrix.
Hi dear Sir I am facing these problem whenever I tried to change number of steps from 51 to 5 or 10 please help me out sir.
#include “…/libdef.any”
// Find a detailed description here
#include “Model/Description.any”
Main = {
// Path to draw settings
#path BM_DRAWSETTINGS_FILE “Model/DrawSettings.any”
// Model configuration:
// For more info on body model configuration options please load the model and double click on:
// #include “<ANYBODY_PATH_BODY>\Documentation\BodyModel.param eters.any”
// The Mannequin file specifies load-time positions for all the segments
// in the HumanModel. This is important for the model’s ablity to resolve
// all the kinematic constraints when the model is analyzed.
// The mannequin file also drives those degrees of freedom of the human
// model that are not governed by problem-specific drivers at run time.
#path BM_MANNEQUIN_FILE “Model/Mannequin.any”
// #define BM_TRUNK_MUSCLES CONST_MUSCLES_NONE
// #define BM_LEG_MUSCLES_BOTH CONST_MUSCLES_NONE
// #define BM_ARM_MUSCLES_BOTH CONST_MUSCLES_NONE
// Model of the human body to be used for the analysis
/// The actual model where all components are assembled
AnyFolder Model =
#include "Model/Environment.any"
  #include "Model/JointsAndDrivers.any"
//--&gt;Folder for design parameters
AnyFolder Parameters =
  AnyVar Distance_From_PelvisContactNode_To_HeelNode = 0.6;
//&lt;--
//--&gt;Use of the object name to insert additional objects inside
HumanModel.Trunk.SegmentsLumbar.PelvisSeg =
  AnyRefNode ContactNode =
    sRel = .Scale({-0.02, -0.18, 0});
    AnyDrawRefFrame Drw =
      ScaleXYZ = 0.1*{1, 1, 1};
      RGB = {1, 0, 0};
//&lt;--
AnyBodyStudy Study = {
AnyOperationShellExec ConvertToAPDL=
Show=On;
FileName =“AnyFE2APDL.exe”;
Arguments ="-i\C:\Users amuk\Desktop\AMMRV1.6.3\AMMR\Applicati on\Examples\SitUpModel\Model\ForceL5.xml-o\C:\Users amuk\Desktop\AMMRV1.6.3\AMMR\Applicati on\Examples\SitUpModel\Model-t\C:\Users amuk\Desktop\AMMRV1.6.3\AMMR\Applicati on\Examples\SitUpModel\Model\APDLsitup.txt";
WorkDir=“C:\Users amuk\Desktop\AMMRV1.6.3\AMMR\Ap plication\Examples\SitUpModel\Model”;
AnyFolder &Model = .Model;
tEnd = 10;
Gravity = {0.0, -9.81, 0.0};
nStep = 5;
AnyMechOutputFileForceExport ForceOutput =
   FileName = "Output\ForceL5.xml";
   /*NumberFormat = thats fine t
   Digits = 15;
   Width = 22;
   Style = ScientificNumber;
   FormatStr = "";
   XMLformatOnOff = On;
   UseRefFrameOnOff = Off;
   AnySeg &L5Seg = Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.L5S  eg;
   AnyRefFrame &L5RefFrame = Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.L5S  eg;
FileName = “files_in/ForceL5.xml”;
UseRefFrameOnOff = On;
AnySeg &L5 = Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.L5S eg;
//include the next line to have a camera in the model
}; // End of study
#include “<ANYBODY_PATH_TOOLBOX>\Operations\RunAppSequence. any”
}; //Main
It depends very much on your drivers and motion if you can reduce it to 5 or 10 steps.
