Parameter Study: Normailzation of output vectors
I am performing a parameter study. My problem is that I would like to
get the angle between to output vectors. Therefor I need to normalize
both of them. I Tried something like this.
AnyOutputFun Vec1 = {
Val = .Model.HumanModel.Left.Leg.Jnt.Hip.Constraints.Reaction.Fout;
 AnyOutputFun Angle = {
   Val = acos({0,0,1}*.Vec1()'/vnorm(.Vec1()));
As “.Model.HumanModel.Left.Leg.Jnt.Hip.Constraints.Reaction.Fout;” is
equal to zero during model loading, I get this error message:" ‘/’ :
Division by zero".
I could imagine some circuitous workarounds in order to calculate the
angle, but maybe you know an easy way.
Thanks a lot
Peter
Hello Peter,
Although not a perfect solution, you can do something like this and it works
fine:
Val = acos({0,0,1}*.Vec1()’/(vnorm(.Vec1())+0.00000001));
Have a good day,
Jean-Olivier Racine
joracine@humancad.com
HumanCAD development team
Nexgen Ergonomics Inc.
http://www.nexgenergo.com/
Of peter.belei
Sent: Friday, March 14, 2008 4:22 AM
Subject: [AnyScript] Parameter Study: Normailzation of output vectors
Val = acos({0,0,1}*.Vec1()’/vnorm(.Vec1()));
Division by zero".
Thanks a lot
Peter
The solution is not perfect, but good enough for me. Thank you.
— In anyscript@yahoogroups.com, Jean-Olivier Racine <joracine@…>
wrote:
> Hello Peter,
it works
> fine:
> Val = acos({0,0,1}.Vec1()’/(vnorm(.Vec1())+0.00000001));
> Have a good day,
> Jean-Olivier Racine
> joracine@…
On Behalf
> Of peter.belei
> Hi,
> Val = acos({0,0,1}
> Division by zero".
> Thanks a lot
> Peter
