Hey Peter,
I have a slightly different suggestion for how to study how changes in the
marker positions alter the motion.
Use step 1-3 as Søren suggested to obtain the best possible marker positions
and segment lengths, update the LocalMarkerCoordinatesAndSize.any file with the
optimal solution, load the model, run SetInitialConditions in the
MarkerPlacementStudy and save a new ModelGait.txt file. This ModelGait.txt file
is the one where you wish to introduce small changes in the coordinates of the
markers.
4). Create a matlab script that can write out the ModelGait.txt with the numbers
that are already in it except all the MARKER specifications. - But use a
different name for the file, e.g. ModelGait-<MarkerChangedName>.txt
- Create a variable in matlab for each marker and initialize them with the
optimized local marker coordinates.
Then run the following loop in matlab:
- Introduce a small change to the marker you wish to change.
- Write all the MARKER specifications in the ModelGait-<MarkerChangedName>.txt
- Execute GaitApplication2 with the following syntax: >> GaitApplication2
ModelGait-<MarkerChangedName>.txt StudyGait.txt (remember to change to POSONLY
analysis)
- When the analysis has completed, copy the file output-euler.txt to
output-euler–<MarkerChangedName>.txt and the output-par.any to
output-par–<MarkerCangedName>.any
- Go to 1 and repeat with a new marker change (remember to put the change you
just made back to the initial value).
When you have run this for all the markers you are interested in, you can
visualize each of the results in new AnyBody models by making the two following
small changes:
In the JntDriver in JointAndDriversOptimized.any change the filename
output-euler.txt to the output-euler–<MarkerChangedName>.txt and in the
HumanModel.any change the output-par.any include statement to
output-par–<MarkerChangedName>.any.
I hope this helps you else write again.
Michael Skipper Andersen
The AnyBody Research Project
----- Original Message -----
Sent: Wednesday, November 12, 2008 10:57 AM
Subject: RE: [AnyScript] Parameter study on Marker error
Hi Soren,
sorry, I meant the ModelGait string. The study gait will not change from each
run of the trial.
many thanks
Peter
— On Mon, 3/11/08, AnyScript Support <anyscriptsup@anybodytech.com> wrote:
From: AnyScript Support <anyscriptsup@anybodytech.com>
Date: Monday, 3 November, 2008, 9:16 PM
Hi Peter
I assume you are using the GaitApplication…
I have not tried this so there might be other ways of doing this, here is my
suggestion:
1 Run gaitapplication2 with the Scale option on, to get the best possible
solution
2 Update the LocalmakerCoordinatesAndSize files with the found solution in
the file outputpar.any so that all segments and markers will be at the
optimal position once the model is loaded.
3 Manually introduce the 2 mm error on the marker in question in the
localmarkerandcoordinateanssixe.any file
4 Rerun the model using the POSONLY option , if you did not introduce the
error it should give the same solution as before but the error should
introduce a slight difference in the found motion
You can not do this directly as a parameter study in AnyBody if you are
using the GaitApplication2, because AnyBody will not execute the
gaitapplication2. The only way to do this in an automatic way would be
control the gaitapplication2 and the console application AnyBodyCon from
another program such as Matlab or similar.
Of peter.worsley
Sent: 03 November 2008 12:03
Subject: [AnyScript] Parameter study on Marker error
Dear all,
I am currently analysing some data taken from a recent study. I would
like to run a parameter study on a few key marker positions. Has
anyone managed to do a parameter study that takes into account a 2mm
marker movement radius (trying to take into account skin movement
artifact and data to model marker postions estimation).
I have gone through the tutorials, but i am struggling a little on
creating a radius as a parameter.
best wishes
Peter
Users of the AnyBody Modeling System help each other create biomechanical
models in the AnyScript language.Yahoo! Groups Links
