Yes this is possible, you can use either floor, ciel or round.
Floor function will take the nearest lower integer
Ciel function will take the nearest upper integer
Round function will round of the number in a clever way
This is an example on how to use the functions:
AnyFloat A1=20;
AnyInt A2=round(A1*2.575);//mult. gives 51.5, it will return 52
AnyFloat B1=20;
AnyInt B2=ceil(B1*2.575); //mult. gives 51.5, it will return 52
AnyFloat C1=20;
AnyInt C2=floor(C1*2.575);//mult. gives 51.5, it will return 51
Best regarads
AnyBody Support
— In anyscript@yahoogroups.com, “Leng-Feng Lee” <lengfenglee@…>
wrote:
> Hi,
> I would like to know if it is possible to do something like:
> int var1
> float var2
> var2=20;
> var1=var22;
> In C/C++, this can be done by:
> var1=(int)var22;
> I can’t do it for AnyScript–where var1 and var2 are system defined
> variables… anyway to go around this?
> Thanks,
> Leng-Feng
