Hi Ceren
I will start by exaplaining how the standing model is driven, it is
all going on in the JointsAndDriver.any file, then i will describe
the concept of initial positions.
The feet are driven to stay vertical on the ground and the are driven
in the forward/backward direction so that the ankle joint stay at x=0;
Then the entire body center of mass is driven in the global x and z
direction so that it stays centered above origo.
The spine is driven by setting the rotation between pelvis and the
thorax, this is the also named PostureDriver.
All dof in the arms are driven by joint drivers on each of the dof’s.
The legs are also entirely driven by joint drivers except the ankle
flexion, since this dof is basically driven by the contact between
the foot and the ground.
In commen for the joint drivers are that they get the values from the
Mannequin.any file.
When you load the model the segments will have initial positions
which are defined by the properties in the Mannequin.any. This is an
easy way to set the model in any kind of initial position. So when
you load the model it will make use of all the parameters in the
mannequin file for setting the intitial position of the model. These
positions serves ONLY as the initial guess on a solution for the
kinematic solver. When solving the kinematics of this problem the
solver will try to fullfill the constraints imposed to the model by
the JointAndDrivers, using the initial positions as a good guess,
nothing else. So it is the joint and drivers that really determines
the kinematics of the model.
If you look at the model FreePosture you will find a model which are
driven entirely like described in the mannequin file. Meaning that
you set the position of the pelvis and it’s rotation wrt. the world
and then drive each joint in the body as an open kinematic chain.
This is also how the initial positions are set in the StandingModel,
but once the kinematics are solved the joint and drivers between the
feet and the floor etc. are imposed on the model instead.
I think it is this fact that has cause you the problem.
You decribe that the upper body rotates with the pelvis, this is
correct, it is because the PostureDriver that drives the rotation
between the pelvis and thorax. You also write that the feets stay
stable on the floor, again this is because of the drivers and joints.
I am uncertain what kind motion you are searching for?
I think you should try to review the JointsAndDriver.any file for the
StandingModel and make a small sketch on how this model is driven.
Then try change some of the settings in the mannequin.any file and
see the effect it has once the kinematics has been solved.
I hope this helps you move on, otherwise please write again.
— In anyscript@yahoogroups.com, “cerensaglamer”
<ceren.saglamer@…> wrote:
> Hello,
> I have a problem regarding the posture of the Standing Model. I have
> been investigating the effects of multiplanar deformities of the
femur
> on knee joints. In order to do this, I modified the Thigh segment of
> the Seg.any file so that it represents a deformed femur. I
calculated
> the necessary posture angles (e.g. PelvisRotY, HipExternalRotation,
> HipAbduction) and wrote them in the Mannequen.any file. I based my
> posture angle calculations on the assumption that when a person
stands
> up, his/her hip joint centers and ankle joint centers are aligned on
> axes that are vertical to the ground on both sides.
> When I load the model, I see on the “Model View” that the body
posture
> is as I want it to be: the hip joints and the ankle joints are
aligned
> on both limbs. I also confirm this by comparing the positions of jip
> and ankle joint reference points in the global frame. However, when
I
> run an Inverse Dynamic Analysis, I see that the upper body rotates
> along with the pelvis while the feet positions stay stable, and the
> hip and ankle joints are not aligned anymore. When I look at the
> MannequinValuesFromModel.any file, I see that the body posture
angles
> that I set have been modified (especially PelvisRotX-Y-Z values).
> To trace the source of the problem, I ran some posture trials with
the
> standard Standing Model (with a non-deformed Seg.any file), and
found
> out that the upper body and pelvis rotation occurs only when there
are
> nonzero HipExternalRotation and HipAbduction values in the Mannequin
> file for the same side.
> I was wondered if any of you fellow researchers experienced the same
> problem. It is very important for my work that the body posture is
> retained after inverse dynamic analysis. Thank you in advance for
any
> help you can provide.
> Ceren
