Questions about Gait3D
Hi, I’m Sungwoo Park from South Korea. I want to ask some questions
about Gait3D in Repository6.2
I’m working on inputting marker data into AnyBody model, and Gait3D is
a good example for that. But when I tried to load the Gait3D model
without any changing the script, I failed. The error message
was, " ‘P1.txt’ unexpected ". P1.txt file is included in the Gait3D
folder of Repository6.2. I have no idea why there is a problem for
datafile.
And one more thing, I used c3d2any to convert c3d file to anyscript
file, but I’m confusing how to use or include those 9 scripts in the
script I made. Do you have any example scripts of using datafile from
c3d2any for refering? It will be a lot helpful.
Thank you~
Sincerely,
Sungwoo Park
Hey Sungwoo Park,
Which version of the AnyBody Modeling System are you using? I just checked
it with the latest available (3.0.3) and it worked well and loaded without
failure.
Please have a look at the GaitUniMiami Application in Repository 7. This
application is a good starting point for your studies. In the beginning
section is a detailed description of how to use c3d2any and the
GaitApplication to drive the model.
Hope this helps, if not, please ask again.
Sebastian
Of cizofu11
Sent: 27. oktober 2008 06:21
Subject: [AnyScript] Questions about Gait3D
datafile.
Thank you~
Sincerely,
Sungwoo Park
