I’m Karla Cassidy, I am currently working on my Masters in University
of Waterloo in Canada. I’ve just started getting to know the AnyBody
software and I can’t figure out how to clear an error. If I run one
program and there is an error then open another window and run that
program the same errors remains even tho I’m on a different program
completely. Is there a way to ‘clear’ the error in the previously
loaded programs?
I am uncertain about the type of error you have, so my answer may not apply
exactly.
If you are running the model and get an error while it is running, it can be
different kinds of errors, typically it can be
Kinematic error: this means that the motion was not resolved correctly
Muscle recruitment error: This means that the muscles could not balance the
model
If it is one of these errors you see, it will appear every time this model
is being used, since this error belongs to the model, my guess is, that this
is what you have seen.
The only way to avoid these kinds of error’s is to resolve the root of them.
I hope this helps you move on, otherwise please write again and include the
error message.
I you have not done so, please consider going through the tutorials on
loaded programs?
Thank you!
