Dear AnyBody Support,
If I want to work only with the AnyBodyCon.exe, which I want to start maybe from an other program, is it maybe possible to install only a few .dll Files from Anybody or will I need always the full installation.
Best Regards Eric
Hi Eric,
In principle it is possible to copy the files and avoid the full installation, but it is likely to be easier to do the normal installation.
If you could write a little more on usage scenario and why you would like to avoid the installation, we might to be able to suggest the best solution.
Best regards Søren
