Right-click → “Plot values” on ArmStudy outputs doesn’t plot (Model Tree)
I’m working with an ArmStudy-based model. After running an operation, I try to right-click → Plot Fm values on brachialis under Main → ArmStudy → Output in the Model Tree, but it doesn’t produce a chart. The same signals do appear in Chart View, but the Model Tree right-click path seems broken for me.
Hi Dilare
It's not the right place to use that command. When I right click on a property inside the Study -> Output folder, the option for plotting the value is grayed out.
The option works for me when I explore to the object directly in the model tree or in the reference folder in the Study, instead of through the Output folder in the Study.
I hope that helps.
