I tried to complete the scaling tutorial by including the scaled femur in the full body model but I always receive the following error message:
Loading Main ...\Application\Examples\StandingModelScalingDisplay\StandingModelScalingDisplay.Main.any"
Scanning...
Parsing...
Constructing model tree...
WARNING(OBJ1) : E:/An..y/1..g/Body/A..n/S..g/ScalingCustom.any : Thigh.scaling_message_Left_Thigh : Custom scaling for 'Left.Thigh' segment is used! Please specify a scaling law should an 'Unresolved object' error occur
ERROR(SCR.PRS9) : E:/AnyBody/12..ng/Body/A..n/LegTD/HipNodes.any : 'Pelvis' : Unresolved object
Model loading skipped
I believe I did everything as described but nevertheless I attached my main file.
It would be nice if somebody could help me with this.
Your file works just fine when I copy into the AMMR v1.5. Could you please double-check? The problem that you mentioned happened a few times for me when I forgot to switch to 1.5.
Yes, i am sorry. It seems that me and my colleague (i tried on 2 different) have already fixed this problem in our repositories and consider them perfectly clean. I took the repository from the AnyScript.org and can see the problem. The fix would be to change ‘Pelvis’ to ‘PelvisSeg’. But I am not sure whether this will have an effect on other models or not. In theory nothing breaks down, but please be aware of that change.
thanks, it works like that.
I noticed, that the tibia changes its direction when using the scaled geometry. Does this mean that the alignment of the knee joint is dependant on the femoral geometry? I guess the epicondyli will indicate the center of rotation?
