When you read in data from a file you will get a “T” array containing the time values specified int he first collumn and data values will seen in the “Data” object .
So you cannot dircetly read the data into an AnyVector.
What you typicall do is the following:
[ol]
[li]Make an interpolation function using the data, use an AnyFunInterpol object for this
[/li][li] If you look up this object in tghe reference manul and scroll to the bottom of the page you will see an example link.
[/li][li] If you really want an anyvector containing the values in the file and you do not care for the time values you can use directly the Data object.
[/li][li] So then write something like AnyVector test =…MyData.Data;
[/li][li] Data will be a matix you may need to write AnyVector test =–MyData.Data[0];
[/li][/ol]
