Firstly,I am wondering what is the meaning of the “Abscissa.t”?
For example, I open the c3d file in Mokka and Vicon, the Abscissa is united by Frame from 388 to 1099. While the results in Anybody is from 2.065 to 5.475. I doubt that it means time united by second.
But when I export the result into text and copy it to Excel, The result seems to be Inconsistent with what I doubt. As you can see the photo below
Secondly, I am wondering where I can find the Angular velocity
Based on my understanding, it’s just time.
Hi Lyd,
As @tracy_huang mentions, the abscissa.t is just the time vector defined in your study. You can control it using the tStart and tEnd properties of the study. If you are using c3d data - your time vector is probaply defined using information from the c3d file object.
You can find more information in this here.
From your post it is hard to see what exactly you are exporting, and thereby what angular velocity you are refering to, but the angular velocity of AnySeg segments is given by the omega property for a given segment.
Bjørn
