I exchange the Seat.stl folder into another seat stl folder in the Seatedhuman.any.
But I cant see the seat.
Thanks for your help.
There is no warnings.
I don't know why....
Are you sure that the FileName path in your anydrawstl class is correct ?
If you moved the seat.stl file to another directory - you must also change the filename parameter to point to this new location
Bjørn
