I am trying to apply the concept of conceptual exoskeleton on Elbow joint
I have followed the step and the learning from webinar, but i am not able to see any variation in ElbowFlexion Moment or moment of FE joint
I am attaching code for reference please help me out it is little urgent
Hi Bhavna,
Unfortunately, I don't see any code for the assistance from the exoskeleton. How have you implemented the assistance?
Hello Divyaksh
I have tried to apply torque using both methods referring to given model of knee joint. Please help me in following right path.
Hi Bhavna,
It is likely that the spring for you have defined in Main is not included in your study. Could you please check that? Also, I noticed that that you may have considered the pos value coming from the rotational measure to be in degrees. It will be in radians.
I would suggest you spend some time going through our tutorials. Going through the tutorials will really help you understand how to work with AnyBody.
