Hi, AnyBody
I want to use the C3D file that I measured at Vicon.
But I didn’t run the MotionAndParameterOptimization process.
this error seems to appear.
ERROR(OBJ.MCH.KIN3) : C:/U…s/t…f/D…p/a…y/A…5/A…n/my/G…)/GaitFullBody.main.any : MotionOptimization.InitialConditions : Kinematic analysis failed in time step 0
May I know the reason why?
I am using the AMMR version 1.5 and AMS version 5.3.
Regards
I don’t have any problem for running your model during the MotionAndParameterOptimization process.
Did you try to run the following operation in the model tree?
Hi, Moonki
Thank you for your reply.
I tried to run the following operation.
Only the text document of OptimizedParameters was outputted.
But the text document of output-euler-* still were not outputted.
Regards
When I run your model in my computer, I could generate all text files.
So I don’t see any problems.
I’m not sure where you would put AMMR folder in your computer.
Are you using the default location?
C:\Program Files (x86)\AnyBody Technology\AnyBody.5.3\AMMR
Then I would recommend you to copy this AMMR folder to other location.
If this is not the reason, I’m sorry but I can’t help you.
