First of all, it seems that your C3D file is not normal, which means that it does not seem to contain proper marker trajectories. Please check it first.
If you want to drive the human model, it will be nice to start with our MoCapModel instead of the standing model.
Which version of AMS and AMMR are you using at the moment?
As I explained in the previous thread, you should really check whether there is any problem in your C3D files. As far as I saw in your previous file, there was no proper marker information in your C3D file.
As I asked you before, which version of AMS and AMMR are you using?
If you are really sure that you are using our MoCapModel, try to upload your model in the debug section. In this case, please specify your AMS and AMMR versions. http://forum.anyscript.org/forumdisplay.php?f=21
Usually in the MoCapModel, the blue markers represent the trajectories of the markers in your C3D files, whereas the red markers represent the locations of the markers in the AnyBody human model.
As far as the blue markers are not changed, you should not expect the change of the human model even if you change the red marker definitions. That is not the correct use of the model.
Of course you can adjust the location of the red markers a little bit. But in principle, that will not change the human motion dramatically.
You can’t change the blue markers in AnyBody because those information comes from the C3D file. And they are one of the input for your simulation. I don’t see any reason why you should modify those information.
