I am having a little problem with a C3D file.
I tested the pendulum tutorial with one of my own C3D file and I noticed that when I load the model my data is in the processedData section and not the Markers section.
Once in the ProcessedData, the Data part of it is always 0.
Is there a special flag that you are seeking in the C3D files to decide whether the data is in ProcessedData or Markers?
I generate the files using the BTK library. I do understand that you do not give support for BTK but if you can point out the error in my C3D file it will be a lot easier for me to fix this problem.
Thanks a lot.
Alexandre
