as I already wrote I have some problems with C3D file. I use the AMS version 5.3.1 and AMMR.v.1.5.1. I use the C3D file in GaitFullBody model, both enclosed in zip file. When I load it I get this error message:
ERROR(SCR.PRS9) : D:/U…s/L…a/r…y/A…x/A…o/A…n/E…s/G…y/ModelSetup.any : Defined At : D:/U…s/L…a/r…y/A…x/A…o/Body/A…n/T…x/M…p/CreateMarkerClassTD.any : ‘PosInterpol’ : Unresolved object
The only one thing I changed are names of two markers in ModelSetup.any (RFRA, LFRA to RFRM, LFRM). These names weren’t the same in model and in the c3d file.
I have some problems with C3D file again, so I ask you for advice. I’m still using the AMS version 5.3.1 and AMMR version 1.5.1. Now I use the model GaitLowerExtremity – only the lower body part, enclosed in zip file. I have 16 markers in my C3D file (called “Chuze3.c3d”). The marker names are “Bacevsky:RASI”, “Bacevsky:LTOE”, etc. When I change the marker names according the file I get the following error:
Moreover when I want to set the prefix name which goes in front of all markers, nothing will change. I get the same error as I would not change anything:
ERROR(SCR.PRS9) : D:/U…s/L…a/TACR/AMMR/A…n/E…s/G…s/ModelSetup.any : Defined At : D:/U…s/L…a/TACR/AMMR/Body/A…n/T…x/M…p/CreateMarkerClassTD.any : ‘PosInterpol’ : Unresolved object
So please, could you help me how can I implement my C3D file?
Thank you very much,
Linda
