DiscStiffness
Does anyone know how to check the stiffness of disc in Anybody?
Thank you very much!
Hi Amin,
First of all, it would be nice to specify which version of the repository you are using - the answer may depend on the version of the AMMR. But for now I will presume it is the latest one.
Normally, the disc stiffness (if switched on using #define BM_TRUNK_DISC_STIFFNESS_NORMAL ON) is defined as a cumulative stiffness of the intervertebral disc and ligaments spanning over this spinal functional unit (I cannot check at this point, but very likely the values came from //Schmidt et al. The Stiffness of lumbar spinal motion segments with a high intensity zone in the anulus fibrosus). If ligaments are introduced at the same time - a fraction of the value is used to represent the stiffness.
Hope this helps,
