The "identifyPlateIndices" is a python script. All of them worked very well...so I'm now confused where the problem is. I think somewhere between the connection Anybody/Python? I've installed the anypytools already. Maybe someone could help?
The exception happens in the python module so it is hard to say what it is.
Do you set the ANYBODY_PATH_PYTHONHOME to point to an external python installation?
Or did you install the new anaconda version into the anybody python folder ?
I set the ANYBODY_PATH_PYTHONHOME to point to the external anaconda path. So I didn't install the new anaconda version into the anybody python folder but external.
Okay, then it could be a issue with your external python installation.
In particular, your version of anypytools, numpy and pandas should be compatible.
Try to run your python script if you can to see if you get any errors.
You could also be missing another dependency that you had in your old installation.
