I am using the GaitLowerExtremity model and I want to export the femur geometry for use in ADAMS and perhaps at a later date ANSYS. If I click on the femur in the model view it highlights the folder drw3 under the model tab on the left. When I right click the folder I have the option to export surface and a box appears allowing me to save as an .stl file. When I name the file and click save, there is a short pause and I am presented with the following message: AnyBody.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
Any advice would be greatly appreciated. I am new to using AnyBody.
As I am still unable to get an stl file of the femur, would you be able to upload one here from the GaitLowerExtremity model?
I would be very grateful.
As it happens I haven’t been able to open the file you uploaded. I have tried it in Adams, Ansys, and Solidworks.
Adams gives the following message:
ERROR: Unexpected text found while reading file: ‘ffÝçÑÙç.ú’
ERROR: The text that the file reader was expecting: ‘outer loop’
ERROR: Unexpected text was read at line number 19057.
Ansys and Solidworks give no error message but fail to open the part.
we may have attached a wrong file, but you should be able to open it in all of the above software. It sounds very strange. Here is the needed file - it can definitely be open using Meshlab (free software) and AMS, of course.
I can open this one in Adams without any trouble. Could I trouble you for an stl file of the pelvis from the same model?
It would be greatly appreciated.
sorry for the trouble with the first Femur. Actually the newest version of AnyBody v5.1 is ready to download and use on our website. In the latest version you\re able to export .stl files from your model in the same scale as preferred.
