Force dependent kinematics, marker tracking
hello,
i want to know something about fdk. when i active it for mocap model, it runs only under inverse dynamic process. if i run marker tracking first, then run fdk, then software cannot converge and solve it for multi-dof knee. but if i load the model and load parameters and run inverse dynamic, then it solve and converge. Is it supposed to work this way?
Hello Ahmet,
I am not sure I completely understand what you are doing. Do you run LoadParameters before running Marker Tracking? It's important to run Load Parameters or Parameter Identification (in case you don't have saved parameters) before you run Marker Tracking.
I am a little bit confused when you say you can run inverse dynamics in one case and not in the other because inverse dynamics uses the outputs of marker tracking. I would suggest first of all that you run your mocap model without the FDK knee. Please also see our tutorials to familiarize yourself with AnyBody.
