Hello, I am trying to create new squat model base on lunge model (AMMRV1.5).
I found some text file (cop.txt, GRF.txt, output-euler.txt, p1.txt) in the folder that contained lunge model. Could you please explain to me the meaning of this file and how to get it? Thank you very much.
If you want to develop your own squat model, then I would recommend you to start from the ‘StandingModel’ in the AMMR.
You need to define your own drivers in order to make a squat like motion. For instance, I would try to play with knee flexion and pelvis-thorax extension drivers.
And instead of using some fixed force at both feet, it is worthwhile to test the ground reaction force prediction code here:
http://wiki.anyscript.org/images/2/2a/AddingGRFpredictiontoaMoCapmodel.pdf
I tried to modify lunge model . this model create by two leg motion, but i would need full body model, i created this full body model and successfully loaded it, but in kinematic analysis appeared some errors. i attached my model and screen shut of error message.
please help me.
Best Regards
M.D
