Im trying to load a C3D file containing a movement captured with a Vicon system. The captured movement is a golfswing with the same marker system as in the MarkerProtocol.any file.
Im using your AMMR PlugInGait_Simple model but get a lot of error messages when doing the parameteridentification.
Constraint #410 is above tolerance 1e-05, error = 0.008017, segment constr. 'Main.HumanModel.BodyModel.Left.ShoulderArm.Mus.DeltoidWrappingPosterior.WrappingSegment'.
Constraint #411 is above tolerance 1e-05, error = 0.007794, segment constr. 'Main.HumanModel.BodyModel.Left.ShoulderArm.Mus.DeltoidWrappingLateral.WrappingSegment'.
Constraint #412 is above tolerance 1e-05, error = 0.007794, segment constr. 'Main.HumanModel.BodyModel.Left.ShoulderArm.Mus.DeltoidWrappingAnterior.WrappingSegment'.
Constraint #413 is above tolerance 1e-05, error = 0.000990, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Talus'.
Constraint #414 is above tolerance 1e-05, error = 0.001600, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Foot'.
Constraint #415 is above tolerance 1e-05, error = 0.000967, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Shank'.
Constraint #416 is above tolerance 1e-05, error = 0.001184, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Thigh'.
Constraint #417 is above tolerance 1e-05, error = 0.000832, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Patella'.
Im having trouble adding the files to this message.
Does anyone know what the problem might be?
//Anna
