Hello, we want to analyze the relevant data of the disabled. I want to ask if Anybody has a model library for the disabled. Or how can we modify a normal human model into a disabled model in the model (for example, comment out a leg in the model). thank you very much indeed.
Hi @Anybody998
The AnyBody body model comes with switches for the different body parts so you can remove a leg by adding #define BM_LEG_RIGHT OFF to you body model configuration.
Here is also our tutorial on modifying the body model:
Bjørn
Hi @Anybody998
I‘m recently working on the transtibial amputee simulation using the mocap model myself. What you said is possible.
Lee
Hi @Bjorn
thank you very much! I will try your method.
jxm
Hi @Nickel_Lee
Is it convenient for you to share the detailed simulation steps, thank you very much!
jxm
