I don’t mind using another marker set that you are using in the anygait model, cause I’m planning to show it to the students and I believe it is very straight forward to understand the concept.
So what is the marker set that I need to follow inorder for my to be able to insert my C3D files and use the AnyGait model…
Is the static trial need to be for a certain pose, like T-Pose or what? and can I use the C3D files that comes out of Vicon if make new mocap trials according to the information that you will provide me with?
Thanks for your reply…
I went through the link you sent me, and I have the following questions:
-I assume VIC is referring to the vicon set up?
-In the static trial, can you tell me what are these markers referring to:
RFEO and RTIO.
-In the dynamics trial, what are the: RTHL (if the RTHI is the thigh marker) and RMMA.
Also, when looking at the Marker.any file, it looks that both the VIC and SIMI are Vicon plug-in-gait protocols, so I can choose which ever one when using vicon?
And wanted to make sure, when exporting the C3D file all the AnyGait needs is the labeled markers only, I mean that I don’t need to do any processing like running the plug-in-gait dynamics modeling or anything, all I hae to do is to label the markers according to the Marker.any file, is that right?
Thanks again for your response…
What do you mean by specifying the type of the force plates? I use vicon system and kistler force plates and then export the C3D file from vicon nexus software…I’m not sure when and where do I need to specify the type of the force plates.
